Re: farmall 200 gov adjustment
Posted by gene bender on March 07, 2009 at 15:02:24 from (67.55.227.228):
In Reply to: farmall 200 gov adjustment posted by redblood on March 07, 2009 at 10:22:56:
With the engine off un hook the clevis.Then open throttle full. Now adjust the clevis so the pin goes in holding carb linkage open full then adjust the clevis. When your gov housing was off did the input shaft have a lot of wobble. They can be rebushed then throttle response will be like new again. I have a jig i made to hold the housing so i can mount on the table of the milling machine and bore the hole to 5/8 then replace with a 5/8x1/2 brass bushing the gov then works perfect.
