Re: farmall 200 gov adjustment
Posted by Redblood on March 07, 2009 at 21:14:30 from (75.218.3.31):
In Reply to: Re: farmall 200 gov adjustment posted by gene bender on March 07, 2009 at 15:02:24:
I too made a jig like your are talking about and it works perfect. I make the bushings with some old brass stock I have. But anyways I adjusted the clevis so the pin slides through with carb full rearward and governer at zero on the spring (forward part of the slack) Seems to be working fine. I need to put the rad back on and "road" test.
By the way Gene how much do the exhaust pots cost to referb for the A pnuematic lift? I have all the pieces but the exhaust pot on the manifold. Actually I beleive I have the bottom of one and the rod that goes through. Do not beleive the flap is still there. The muffler rusted - fell into the manifold and I have not dug it out yet. That tractor is possibly next winters project.
