Re: Farmall MD Clutch Questions
Posted by Haas on November 16, 2005 at 18:23:49 from (12.65.0.121):
In Reply to: Farmall MD Clutch Questions posted by Matt Compton on November 16, 2005 at 16:35:38:
I don't think a starter from an M will fit the MD. One of the big suppliers of used tractor parts has starters for the MD listed in their catalog. It won't let me post with the name herein. The MD starter is a 12 volt starter, as all MDs were 12 volt, using two 6 volt batteries connected in series. To remove the clutch, remove the bolts that hold the clutch release carrier to the top of the housing. Remove the clamp bolts (You'll need to take loose all the external connections to the clutch) that hold the clutch release fork to the cross shaft. The fork is keyed to the cross shaft with two heavy washers located between the clamps and held in place by the bolts. Remove those washers. If there is anything else holding (I can't recall exactly) the cross shaft, take that loose. Now the cross shaft will slide out and you can remove the clutch fork. Take out three of the bolts that hold the clutch plate to the flywheel. Reinsert those bolts in the three holes in the clutch plate that had no bolt. Tighten those three bolts which compresses the clutch springs and releases it. Now unless I forgot something, the main drive shaft should tilt down enough to slide past the transmission coupling and be removed. Take the other three bolts out of clutch and remove it. I may have forgotten something as it has been a few years since I did this. The service manual says you can remove the clutch without removing the cross shaft. I got mine out without doing that, but I could not get it back in, so it's easier to just go ahead and take out the cross shaft. It's a dirty job down under there. If you have any questions, just send me an E mail.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
