CUB lift capacity
Posted by Kevin (FL) on November 21, 2005 at 05:32:38 from (12.77.199.236):
We're in the final stages of drawing up and then building a couple of landscape rakes for our Cubs to help out with hurricane cleanup. My question relates to the weight lifting capacity of the touch control system and more importantly--how much weight can be lifted without front weights? We'll be building two different design 5' rakes as light as possible--one will use old RR spikes for the tines and the other will have the standard (1"x 5/16") spring steel tines. We plan to have a pivot point slightly aft of the drawbar to allow for lifting when the rake is not in use and for adjustments while dragging. I expect we'll need to get front weights but they're a little harder to come by than the rear weights--(we have plenty of rear weights).
Post a Followup
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
