Re: Trouble starting.
Posted by fisherman on November 24, 2005 at 07:12:53 from (24.208.82.160):
In Reply to: Trouble starting. posted by Fisherman on November 23, 2005 at 14:44:30:
I looked at the generator last night and it was a remanufactured 6 volt from beatrice,Neb. I didn't notice the coil.
Yes, John the lights were burnt out so prior to the tractor starting redid the wiring of the top lights down to the steering wheel. From there I put 12 volt lights in because the battery was 12 volt and the dim/high switch.
I've replaced the cable to the starter with 1 guage and placed the same 12 volt battery that it came with back on. Hit the foot pedal and the postive battery cable just popped.
So I guess I will put the 00 guage battery cables on and put a 6 volt battery. Thanks for your help I will keep working on it until it works.
Thanks for your help-scott
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
