Re: Trouble starting.
Posted by El Toro on November 24, 2005 at 07:52:09 from (152.163.101.13):
In Reply to: Re: Trouble starting. posted by fisherman on November 24, 2005 at 07:12:53:
If that coil is 6 volts. You may have fried it unless there's a ballast resistor installed to drop the 12 volts to 6. Hal
Post a Followup
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
