Re: Farmall B magneto problems
Posted by El Toro on November 26, 2005 at 15:29:25 from (205.188.117.73):
In Reply to: Farmall B magneto problems posted by Frank Stalfire on November 26, 2005 at 14:11:13:
Pull the cover over the coil and use a flat blade screwdriver to check the magnetism in the mag's
magnets. This is what creates the spark when it passes the coil. If they're good they'll pull that screwdriver in quickly. If the pull is very weak you may another mag. Hal
