Re: Anybody familiar with the Magnum motor?
Posted by P Backus on December 02, 2005 at 12:43:30 from (69.128.32.197):
In Reply to: Re: Anybody familiar with the Magnum motor? posted by JakeF on December 02, 2005 at 12:10:11:
Thanks for the insight Jake. Is that cam gear steel or aluminum? I
was thinking of pulling the head this winter anyway to try to find
the coolant leak, so if I have the head off, it might just be easier
to pull the whole cam? I just can"t figure out why it suddenly quit
using coolant, from a gallon a day to nothing.
My reasoning on the oil cooler is that oil pressure is higher than
coolant pressure, so wouldn"t it get oil in the antifreeze, not the
other way around? Have you found that to be true, or is
something else going on?
Thanks again for the help!
Paul
