Re: 34 in Rims vs 38s
Posted by Nat on December 05, 2005 at 08:36:47 from (64.80.108.52):
In Reply to: 34 in Rims vs 38s posted by Jim Allen on December 05, 2005 at 07:25:59:
It was mostly a matter of cost. The smaller tires and rims were less expensive, and IH could pass the savings on to its investors.
If you're on dry ground, the 34" tires are fine. These tractors didn't have much ground clearance with the 34-inchers, and if you get in mud, look out. You're going to bottom out, quickly.
One thing about the smaller tires is that your actual ground speed is much slower than what the tachometer indicates. You probably think you're going great guns with all sorts of extra horsepower... It's the small tires; they have the same effect as running in a lower gear.
