power steering problems on a 300IH
Posted by Ron from Minn on December 07, 2005 at 21:23:43 from (65.73.52.176):
Power steering is plumbed into live hydraulics and won"t work. If you pull the middle hydraulic lever back as to run a hydraulic cylinder it works with a strange noise for about 20 seconds then stops. there is no cylinders hooked up to the outlet when I do this. Whats up with this and how do I correct it. It works great for 20 seconds, I can turn steering either way but then it quits.
