Re: power steering problems on a 300IH
Posted by Allan in NE on December 08, 2005 at 04:05:24 from (148.78.243.26):
In Reply to: power steering problems on a 300IH posted by Ron from Minn on December 07, 2005 at 21:23:43:
Ron,
Sounds like someone left out the flow divider or just plain has it plumbed in wrong.
You hit the remote and then the steering is being fed. A few seconds later, because that little 3 gallon steering motor is the only load, you're up against the pressure relief and the system starts dead heading.
Check to see where the pressure port is plumbed from the pump. It has got to go to a flow divider first.
I think someone has added that power steering in the system downstream. Won't work.
Allan
