Re: h trans lock up
Posted by riverbend on December 08, 2005 at 03:21:38 from (208.160.34.163):
In Reply to: h trans lock up posted by tn terry t on December 07, 2005 at 21:27:50:
It sounds like you will have to look inside the gearbox to see what is the problem. When teeth start breaking, usually something is out of position. That and the grating feeling could indicate a bad bearing.
Will the transmission still shift gears ?
