Re: double wheel weights on farmall h good or bad?
Posted by Allan in NE on December 11, 2005 at 05:47:38 from (148.78.243.26):
In Reply to: double wheel weights on farmall h good or bad? posted by lekander883 on December 10, 2005 at 20:30:02:
Lek,
You're going to need more than two sets of weights.
My old H has one factory set on the inside next to the wheel, then an "off-breed" outter set. I then added calcium up to the brim in the tires and that brings it to about 600 lbs per side.
Don't forget to air up those fronts to 'bout 55 or 60 lbs also.
Allan
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
