Re: 6 VLT BATTERY OVERCHARGE/SHORTING OUT?
Posted by gene bender on December 12, 2005 at 03:27:49 from (66.43.221.81):
In Reply to: 6 VLT BATTERY OVERCHARGE/SHORTING OUT? posted by RANGEL on December 11, 2005 at 19:19:05:
NO overcharging will not cause that nor will a bad reg. Are you sure your starter button isnt stuck and also the starter locked on the ring gear. I would remove starter and check it.
