Farmall Tractors Discussion Board |
Re: starting on gas switching to diesel
Posted by Bob M on January 02, 2000 at 11:17:52 from (171.215.34.87):
In Reply to: starting on gas switching to diesel posted by bob on January 02, 2000 at 10:37:51:
The IH gas start diesel has a unique cylinder head and valve arrangement. It's got an auxiliary "starting valve" in each cylinder that connects a starting chamber (containing the spark plug) for each cylinder. When the starting valve is open, the compression ratio is significantly reduced, making the engine easier to crank. When you pull the starting (or compression release) lever a bunch of things happen: It opens the starting valve in each cylinder; it opens a diverter valve inside the intake manifold to divert inlet air thru the starting carburetor; it releases the float in the starting carburetor so the carb fills with gas; it closes the primary circuit to the ignition coil. Now when the motor is cranked it'll start and run as a low compression gasoline engine. After the motor warms for a minute or two on gas, the starting lever is moved to the run (or diesel) position. This closes the starting valves, effectively raising the compression ratio to the diesel range (about 14:1), moves the intake manifold diverter valves so only air is fed to the engine, closes the float valve in the carb, and shuts off the ignition. At the same time the injection pump starts feeding fuel to the injectors. The motor is now running as a diesel. The starting system is almost fiendishly complex, but properly adjusted it DOES work, and permits a relatively small battery and starter (or even a hand crank!) to start a fair-sized diesel engine.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
