806 jumps out of high range
Posted by 806 guy on December 18, 2005 at 14:14:04 from (216.46.145.16):
Farmall 806 jumps out of high range as soon as you let out the clutch problem just showed up instantly worked fine until then. Seems to work fine in low and reverse range. I replaced the shifter fork and the shifter sector both showed some wear but it did not help. I am wondering about the sliding gear that the shifter fork moves I can not tell what the internal teeth are like without taking apart the transmission IF any one has any suggestion your help would be greatly appreciated
