Re: Leaking Super M
Posted by Bob M on December 19, 2005 at 06:10:40 from (151.190.254.108):
In Reply to: Leaking Super M posted by Retcol on December 19, 2005 at 05:28:16:
Leak could be from any of (3) possible sources. So you need to figure out exactly WHAT is leaking. Possible sources: 1 – Rear main seal in the engine - will leak crankcase oil. 2 – If the tractor has belly pump hydraulics, the hydraulic pump input shaft seal could be leaking. The leak will be hydraulic fluid (is thinner than crankcase oil and more or less clear in color.) Note: If your Super M has live hydraulics (the hyd pump is on the right front side of the engine) it cannot leak hydraulic fluid from beneath the tractor! 3 – Transmission front seals (input shaft and/or hydraulic pump drive shaft seals). These will leak heavy transmission lubricant. Also you can remove the dust cover from the underside ahead of the transmission, shine a light up there and probably see the source of the leak. ----- FWIW #1 is most difficult to correct – requires splitting the tractor. #2 and #3 however are relatively straightforward. These require only minor disassembly (removal of the hydraulic pump, tranny input shaft, etc) to get at. My experience is #3 - transmission shaft seals - is the most common source of leaks – and fortunately also the easiest (and cheapest) to correct.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
