Re: Leaking Super M
Posted by Craig T on December 30, 2005 at 18:37:17 from (204.11.176.189):
In Reply to: Re: Leaking Super M posted by Bob M on December 19, 2005 at 06:10:40:
Bob, I have a Farmall H that also has a leaking seal coming from the transmission that drives the Lift-all. I am wondering if a H is like a M to get those seals out. In the shaft that drives the pump there are 2 cotter pins, do I have to remove both of them? Also, I see two shafts that run from the transmission forward. Does the top one have anything to do with the Lift-all pump? If it does how do I get it disconnected? Thanks, Craig
