Farmall H carb. still leaks
Posted by John in CT on December 20, 2005 at 18:29:17 from (69.24.45.49):
My carb. on my Farmall H still leaks from the metering nozzle clamp nut. I put the origional needle valve cage (screw driver to install) and steel tipped needle back in. I lapped the needle in with valve grinding compound. It seems to be sealing ok. I figure my leak could be comming from 2 places, the washer at the metering nozzle clamp nut or the needle valve cage washer. Those 2 washers are the same IH washer. Did anyone ever have a problem with those washers? Can I replace them with a copper ones? Is there something I could put on the washers to stop the leaks? Thanks!!
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
