Re: Super A won't start - HELP!!!!!!
Posted by El Toro on December 31, 2005 at 06:12:24 from (205.188.117.73):
In Reply to: Re: Super A won't start - HELP!!!!!! posted by Mark in TN on December 31, 2005 at 05:52:15:
I posted further down on that list earlier this morning too. When No1 piston is at TDC on the compression stroke both valves on that cylinder are closed. This is where your engine power is made when the atomized fuel is ignited by your
sparkplug. Put some chalk on the timing mark so it's easy to see. Any snow in TN? It's just cloudy here in MD about 40 degrees. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
