allen in ne possible wf headache cure
Posted by scotc on December 31, 2005 at 20:40:16 from (65.220.16.62):
That axle center is the same as under our 756. The tie-rod-to-spindle arms look way toed out. would it help to pull them, lengthen the tie rods, and move the arms out closer to being parralel with the wheels? they are actually toed in on the 756. might get the stopblock alignment to where you can get more wheel cut.
