Re: super A axle bearings
Posted by steve the taximan on January 04, 2006 at 05:17:35 from (209.213.227.197):
In Reply to: Re: super A axle bearings posted by gene bender on January 04, 2006 at 04:27:33:
By right side, I do mean pass. side. To remove final drive housing, do I just unbolt it from diff shaft housing and slide it off? Does bearing and drive gear stay on shaft and what about inner seals-do they get damaged? Does diff shaft then just pull out? Thanks for your help.
