Super C Hydraulic Pump mystery
Posted by jdhdon on January 05, 2006 at 06:31:00 from (68.208.204.7):
My pump doesn"t seem to match the Pesco or Thompson pumps shown in the parts manual. Mine does not have any relief ball check valve and can be split in half by removal of two 3/8" x 1 3/4 bolts. The opening in the engine casting also does not have a seal. Rather, there was (emphasis on WAS) a O-ring type gasket around the shaft boss on the pump. When I split the pump apart, there is a oval rubber ring in a groove around the two gears. This rubber ring and the outer gasket around the drive gear is all that"s wrong. My local Case IH dealer says he can"t get parts for the Super C pumps..not to menntion this one doesn"t match the Super C drawings in the Parts Book. Mine appears to have numbers stamped into the pump inlet casting: 3?007R92; ?1101202 D63; 4195P03. THere is also a cast number 05-31. Can anybody tell me 1) where this pump is used and 2) where I might find parts for it? Thanks.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
