Re: Working on the M
Posted by Randy-S.E.MN on January 08, 2006 at 07:06:52 from (206.9.216.45):
In Reply to: Working on the M posted by Randy-IA on January 07, 2006 at 18:47:23:
I had the same problem. I had 180 degrees worth of play in wheel. I disassembled the upper bolster and post and found the the upper bushing surface was wore REAL bad. I chucked it up in my Lathe and welded up the entire top bushing surface and was gonna machine it back perfectly on the lathe. A problem occured though. The entire post warped from the heat, and I thought I had ruined it. I called up a machinist-blacksmith that I knew and he said that warpage is perfectly normal and that he could fix it. So I took it over to him and for $50.00 he straightened it out and machined the bushing surface to spec. The front bolster kit is available from Carter & Gruenewald...about $130.00.
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
