OT truck problems
Posted by tn terry t on January 10, 2006 at 03:23:53 from (152.163.101.13):
i put this on the truck fourm and got no responce so i thought i would try you guys i have a 80 model f150 4x4 that i run parts for my farmalls the brake mastercylinder keeps leaking fluid from around the top seal i have replaced the seal or gasket from the top it will hold a day or two and starts leaking again the cylinder is almost new and has good pedal you guys think maybe its buildind back pressure somehow and makung it leak? or maybe the drums are wore our causing too much fluid being needed to work the rear shoes and is back feeding when pedal is released? grasping at straws i know . i just dont know hope someone can help thanks
