Re: M carb trouble?
Posted by Brownie 45 on January 11, 2006 at 06:20:53 from (207.177.82.14):
In Reply to: M carb trouble? posted by Troy Shelton on January 11, 2006 at 06:04:57:
Remove drain plug on bottom of carburetor and check for adequate fuel delivery. If there is no drain plug, crack the fuel line where it enters the carb to check for adequate fuel flow. If fuel flows freely, check carb inlet screen where fuel line enters carb. If no problem is found, The needle & seat/float could be causing trouble. Also try opening the load jet 1/4 to 1/2 turn.
