Re: M carb trouble?
Posted by the tractor vet on January 11, 2006 at 06:23:43 from (4.124.71.161):
In Reply to: M carb trouble? posted by Troy Shelton on January 11, 2006 at 06:04:57:
You have junk plugen the inlet of the sediment bowl and more then likely it is not a carb problem , i have found everything under the sun plugen the inlet so i would drain the gas out of the tank and pull the sediment bowl out and clean the tank .and work my way down to the carb first.
