Re: M carb trouble?
Posted by old on January 11, 2006 at 08:04:46 from (207.69.139.13):
In Reply to: M carb trouble? posted by Troy Shelton on January 11, 2006 at 06:04:57:
Either one of the other 2 guys could be right. Lets start this way. First remove the sediment bowl, open up the gas shut off, do you get a good flow of gas that way?? If so then put bowl back on and romove the line at the carb, turn gas back on, do you get a good flow?? If yes then your problem is in the carb, if no on the other 2 places your problem is in the line or tank.
