Re: Volts to plug
Posted by Janicholson on January 11, 2006 at 11:58:09 from (66.173.50.7):
In Reply to: Re: Volts to plug posted by old on January 11, 2006 at 11:42:55:
There is good reason to use an anylizer, not a volt meter to measure the voltage. ZZAAPP. Not a good idea.
Plug voltage varies from 5000-25000 volts based on demand, not supply. Thus there is no substantive difference between different primary voltages (6-8-12). Capacitive Discharge Ignition can be an exception, in that it generates spark in a totally different scheme. Not too many CDI systems are used in Farmalls. These CDI systems are not electronic ignition as we know them.
Opening up the plug gap, to assist the ignition of fuel is good today (especially because fuel has far less deposit forming additives). The voltages are higher as a result, but unless the secondary (high Voltage) parts break down, starting and operation will improve.
I hope this helps, JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
