Update on Shawn's SC
Posted by Keith-OR on January 11, 2006 at 15:51:09 from (207.200.116.203):
Cleaned up timing cover,installed new front seal,put on new gasket. bolted cover back onto motor.
With use of special attachment I made, pressed pully back on crankshaft using porta power.
Bolted polster back on front of engine. Tractor is now back to the point that it can be moved on it own wheels.
Water pump and housing are cleaned and ready to be install. Have all gaskets made, so will be putting pump on later today.
Keith & Shawn
