Re: Stuck upper petcock
Posted by williamf on January 21, 2006 at 04:05:22 from (69.19.14.18):
In Reply to: Stuck upper petcock posted by fisherman on January 20, 2006 at 12:13:39:
You can, as others said, either clear it with a piece of wire or screw it out and clean or replace.
It does matter that the oil not be over filled; I don't know this from my own experience but heard Click and Clack explaine that if the oil is too high the crank shaft will whip it into foam and it won't pump properly.
Good luck, Wm
