Re: IH 239DT Rebuild Info Questions
Posted by P Backus on January 23, 2006 at 06:42:24 from (69.128.32.83):
In Reply to: IH 239DT Rebuild Info Questions posted by DF on January 23, 2006 at 06:12:00:
Bearing shells can be replaced in-frame without taking the crank
out. You loosen the main caps enough so that the crank drops
down maybe 1/16". Then take one cap off at a time and replace
the shell in the cap, and push the other shell around the crank
by pushing one end of it until it starts coming around. Same deal
with seals. Thing is, without taking the crank out, it"s pretty
tough to mic the journals to see if they"re worn or even if it"s
been turned undersize. It"s easier on the rods because you can
push the piston up a bit so you can mic the journal. Make sure
you measure them in different places to see if they are out of
round.
They have TISCO rebuild kits on this website, over on the left.
Paul
