Re: Converting to two way hydraulics
Posted by Janicholson on February 14, 2006 at 07:04:49 from (199.17.6.175):
In Reply to: Converting to two way hydraulics posted by NSC on February 14, 2006 at 06:22:21:
The pump you need fits a stage 2 Super H. If it does (and you have a late H with the same hole spacing on the distributor drive casting you will remove) then all is well. If you have an older H, I think there is fudging needed in the top bolt hole location to adapt the pump. The gears on newer Hs, super Hs are stronger and work with pump loading. Older Hs have gears that have had failures (hub on cam drive, and some tooth failure) Cam drive bolts have different thread rotation for the correct drive, keeping the bolt tight under load.
A resevoir is needed, often the belly pump is taken out of its housing, and the housing used as a res. Good luck, I hope the parts you are considering are the correct ones. The gear thing is important for moderate to normal/heavy use.
JimN
