Re: Farmall H Drive shaft bearing and countershaft
Posted by farmallhal on February 15, 2006 at 08:54:32 from (64.24.35.17):
In Reply to: Farmall H Drive shaft bearing and countershaft bea posted by shagle on February 15, 2006 at 08:16:10:
What is the s/n on your tractor as parts change depending on s/n? Do you need bearing part no's. for both ends of shafts or just the forward ones you have been taking apart? You should also replace the pilot bearing in the transmission shaft since you will have it apart. Can't help with removing the bearings and/or oil seals as I've never done one. Hal
