Re: Delco 10SI Alternator Problem
Posted by Bob M on February 15, 2006 at 15:40:36 from (69.205.121.140):
In Reply to: Delco 10SI Alternator Problem posted by Robert Lorencz on February 15, 2006 at 14:37:14:
Robert - Sounds like the interal regulator went bad - and they do sometimes.... Another (long shot) possibility is a bit of metal got between the regulator shorting tab and the alternator back cover. This bypasses the regulator causing the alternator to "full field" and go overvoltage.
Like Bob indicates below, the 10SI regulator is cheap and easy to replace. No special tools are required and it can be accomplished without removing it from the tractor.
