Jacking up the front of an H
Posted by Elk Farmer on February 16, 2006 at 13:47:13 from (152.163.100.65):
How do you jack up the front of an H? Do you put a 4x4 under the frame behind the front wheels being carefull not to hit the front pully. What it the best and safest way.
Thanks
Elk Farmer from Michigan
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
