Re: Drive shaft pilot bearing Farmall H
Posted by tn terry t on February 16, 2006 at 16:05:48 from (64.12.116.65):
In Reply to: Re: Drive shaft pilot bearing Farmall H posted by shagle on February 16, 2006 at 15:38:00:
hey friend what EVER YOU DO PLEASE make sure you get all fragments of old bearings out of that transmission! i am just now putting back mine cause of a little needle bearing . i had a axle seal leaking pretty bad. i guess that i let the fluid level get a little low.anyway it sucked up that little needle from the pilot bearing and DESTROYED my transmission i had to replace 4 gears plus the driveshaft and guess what, when i took the drive shaft out all of the little needle bearings were there i guess previous owner must have replaced it some time. i replaced all bearings in that transmission from Motion Ind. for less than half what the dealers wanted
