Re: Hydraulic problems
Posted by Janicholson on February 21, 2006 at 06:29:40 from (199.17.6.175):
In Reply to: Re: Hydraulic problems posted by Nat 2 on February 21, 2006 at 05:40:58:
With respect, a quick front of the Texas Instrument 85 check of the numbers has about 9.86 sq unches of area on a two inch cylinder. Times the pressure = about 12,800# of force, times 2 for two cylinders = about 25,000#. With very bad cylinder position this might not lift anything, but it would probably bend it.
Something is wrong. Bypassing cylinders or ? One way cylinders with top as resivoir would not show leak to outside.
JimN
