Re: IH Carb Adjustment
Posted by Wayne Swenson on February 26, 2006 at 10:20:06 from (24.181.155.110):
In Reply to: IH Carb Adjustment posted by IronHorse on February 26, 2006 at 08:37:58:
Has the carb been cleaned? Is the air cleaner serviced? Check the basics first and be sure the ignition timing & spark quality are correct; ignition problems sometimes act like carburetion troubles. With the engine warm & running at wide open throttle (WOT), turn high speed mixture screw in until the engine begins to starve for fuel. Then turn the screw out until the engine begins to blubber. Now find the "sweet spot" in between the two settings. If you are working the engine (plowing, etc.), then the high speed screw needs to be turned out 1 turn or more beyond the "sweet spot" to be sure the engine isn"t starving for fuel and can develop its rated power. The same procedure can be followed for idle mixture with the addition of the ldle stop screw to set the low speed RPM. On the “M” carb, the idle mixture screw is an air adjusting screw so turning in will richen the mixture and out will lean the mixture. Aren"t carbs fun!!
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
