Farmall A Filter/Oil
Posted by plh_in on March 14, 2006 at 04:02:58 from (207.250.220.194):
I just got a Farmall A. Where can I get the oil filter for this & what is the part no. when ordering it?? Also, should I use straight 30wt oil? &... how much (capacity) does this hold when refilling?
Is there a service manual that would be useful that I can still get?
Thanks alot!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
