Re: Farmall A Filter/Oil
Posted by El Toro on March 14, 2006 at 04:32:20 from (152.163.100.65):
In Reply to: Farmall A Filter/Oil posted by plh_in on March 14, 2006 at 04:02:58:
Napa sells Wix oil filters and the filter number is 51172 cartridge and 51051 spin on. Any auto parts store can cross-reference these numbers too.
I would use #30 wt oil. It should hold 5 quarts. You should have petcocks on the oil pan for checking the oil level. It needs to be between these two petcocks. I would keep it at the top petcock for heavy usage. Check with Binderbooks for a manual or I&T manuals. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
