Re: farmall A questions
Posted by Paul in Mich on March 14, 2006 at 11:12:24 from (66.227.138.249):
In Reply to: farmall A questions posted by Bill Geer on March 14, 2006 at 06:22:37:
Bill, I believe that 65lb. was the amount of torque required on the old head gaskets. The new gaskets furnished by Case IH suggest 85 lb torque, starting with the middle bolts and working outward side to side in 10lb increments up to 40lbs, then 5lb increments thereafter to 85lbs. Once at 85lbs, go back over each bole twice more at 85 lbs. As to your Mag timing, Make sure your timing mark on the flywheel is set at TDC on compression stroke of #1 cylinder. The rotation should be the same direction as the motor runs. Ease up to the timing mark, being careful you don"t have to back up. At that point, the mag should not have clicked. When you are satisfied that this condition exists, remove the Mag cap and verify that the rotor is pointing to #1 position. This should be approximately between 1:00 and 2:00 when viewed from back to front of the Mag. If that position is verified, then go to the next step. If not, remove the rotor, and the 2 screws holding the rotor shaft plate to the mag, then align the gears so that when you relocate the rotor shaft that the rotor will then point to the correct position. There should be alignment marks on the gears, but not necessarily. Then you go to the next step. Loosen the mag and rotate the top toward the engine, then slowly rotate away from the motor until it clicks. Voila, you should be in perfect time. Your ignition wiring should go clockwise of the mag cap from #1 to #1 plug. Next to #3, Next to #4, Next to #2.
Home
| Forums
Today's Featured Article -
When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
