Re: Farmall H 12 Volt Conversion.
Posted by Janicholson on March 16, 2006 at 09:36:05 from (199.17.6.175):
In Reply to: Farmall H 12 Volt Conversion. posted by Bunchs33 on March 16, 2006 at 08:54:01:
Hs have various starter mechanisms. None (to my knowledge) came with a solenoid. If you hav a push button start, or a key start system, here is your answer. Change to a 12 volt with 4 terminals. looking from top down with the terminal end of the device away from you, put the battery cable connection, and the power wire to the amp gauge, on the left terminal. The next terminal is probably a small one labeled S this gets the wire from the key or push button to start the tractor. The next terminal is probably labeled I it is to be connected to the coil side of a ballast resistor (if your coil is designed to ues one, or you are using the 6v coil which needs the ballast resistor Mid 60s chev, or chrysler will work). If your 12v coil is labeled "no external resistor required" then leave this terminal naked. If you have a ballast resistor, or are going to use one, the wire from the Key or "on off" sw that powers the coil should hook to the other side (non-coil side) of the ballast resistor) The purpose of the I terminal is to bypass the resistor when starting to allow for voltage drop from the starter, giving a hotter spark at cranking. Good luck I hope it helps, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
