Farmall H 12 Volt Conversion.
Posted by Bunchs33 on March 16, 2006 at 08:54:01 from (12.203.119.157):
If you switch a 6 volt H over to a 12 volt H, should you change the 6 volt solenoid over to 12 volt. I have a 12 volt solenoid to put on, but it has 4 terminals and the 6 volt has 3 terminals. Any help would be appreciated.
