Re: COIL S. M. 12 VOLT
Posted by Bob M on March 20, 2006 at 13:41:48 from (69.205.119.17):
In Reply to: COIL S. M. 12 VOLT posted by BUCK.E on March 20, 2006 at 13:13:20:
The coil should get barely warm to the touch. Sounds like you've got a 6 volt coil running on 12 volts without a ballast resistor. Either add a resistor between the ign switch and the coil, or replace the coil with an interally ballasted "12 volt" coil.
You've done no harm installing the distrubutor gears 1 tooth out of time. If you time the spark either statically or with a timing light you merely end up with the distibutor body turned slightly from it's "normal" position.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
