Re: Flat rear tire on Farmall A
Posted by FatRedneck on March 23, 2006 at 07:38:31 from (205.188.116.133):
In Reply to: Flat rear tire on Farmall A posted by Larry Ed on March 23, 2006 at 07:24:06:
you certainly shouldn't have to take the weight off to fix the tire, if your only putting a tube in it you can do that with the tire and all on the tractor. you have to jack under the axle, then use tire irons to pull the outer sidewall of the tire off the rim then replace the tube making sure not to pinch it while replacing the tube or it'll be flat again in a jiffy. once you get the tube in the tire just pop the tire back on the rim and air it up. hint: plenty of hot soapy water is a godsend when doing this project.good luck
