Broken pieces from Transmission
Posted by Robert Lorencz on March 26, 2006 at 16:43:37 from (205.188.116.133):
third party image
Decided to drain the oil from the transmission/rear end on my "51 Super A today due to its "brown" color. When it was finished I stuck my finger in the drain hole to see if there was any crud laying on the bottom and found these 2 broken pieces. I can't find anything in the Parts Book that they might have broken off of. Transmission works ok, usual gear noise, no PTO/belt pulley on this tractor. Any ideas?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
