Re: farmall M hydralic leak
Posted by CNKS on March 26, 2006 at 19:53:11 from (204.249.178.138):
In Reply to: farmall M hydralic leak posted by dairyman on March 26, 2006 at 18:38:21:
If it is leaking from the reservoir, you will see it. If you don't see it, the seal on the pump is shot, and it is leaking into the crankcase. A new seal and a speedy sleeve on the shaft (if badly grooved) will fix the problem. Open the top petcock on the oil pan and see how much oil comes out.
