Re: WD9 won't run on diesel
Posted by Ron in Nebr on March 28, 2006 at 14:43:47 from (12.192.38.133):
In Reply to: WD9 won't run on diesel posted by OK PSU Kid on March 28, 2006 at 13:18:28:
Those decompression linkages are notoriously touchy, so yeah, check that first. Since you're getting fuel out the stack(I assume diesel) it's likely you have everything bled out good. If you open the throttle a bit while running on gas then crack the bleeders on the injectors you get good fuel, right? Must be not sealing the cylinders when you switch over from gas. When you pull your valve cover, make sure that when it's on the diesel side there's clearance between the starting valves and the cam that operates them. Also make sure none of the starting valves are hung open. Might not hurt to double check valve clearance on all the valves while you have it off. A quick check to see if anything basic's wrong would be to pull the coil wire and crank it over in the gas mode. Then, while cranking, switch it to diesel. The extra compression should slow down the cranking speed by quite a bit.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
