Re: Farmall H 12 volt battery in 6 volt system
Posted by Nat 2 on March 30, 2006 at 05:01:51 from (64.80.108.52):
In Reply to: Farmall H 12 volt battery in 6 volt system posted by combinekid on March 29, 2006 at 22:42:48:
Go with 6 volt or 12 volt. Don't mix the two. You're just asking for problems.
It's not just "switch some wires around" to make a 6 Volt generator into a 12 Volt. Some 6 Volt generators will ALMOST charge a 12 Volt battery without major modification, but it's dumb luck finding one like that. It's a manufacturing defect, not a feature. You probably don't have one.
You need to answer a question for yourself: Do you want original, or modern? If you want the tractor to be original, go with a 6 Volt generator, regulator, battery on positive ground. Otherwise, go 12 Volt, buy an ALTERNATOR (around $50) and hook things up negative ground. The modern 12V system will be more reliable and will require less maintenance.
If you have to buy the generator and regulator, then there's no sense in wasting your money. An alternator will be cheaper, and then you don't have to buy a new battery.
